2 members (Brian Moore, 2-Ton), 158 guests, and 3 robots.
Topics128,113
Posts1,056,279
Members48,439
#936480 04/17/2013 5:19 PM
My 6 cyl. smokes from the valve cover after running for about 2 miles. any ideas?
boyle #936504 04/17/2013 7:09 PM
Are you sure it is smoke and not water vapor? As the engine warms up,surfaces that were cooler are now being warmed up, including the oil. Sort of like when you put cold water in a glass on a warm summer day, you get moisture forming on the ouside of the glass. Tempeature contrasts cause moisture to form on metal surfaces inside the engine.
boyle #936517 04/17/2013 7:38 PM
As you drive down the road the blow-by is sucked out the tube on the block. However when you are stopped it rises and comes out the valve cover vents. That is not unusual and is only a problem in excess. If the tube is plugged then it will always come out the valve cover along with a film of oil.
1951 1 Ton Completed
boyle #936532 04/17/2013 8:27 PM
What does the smoke smell like?
