hi all
i started putting a pertronix ignitor this weekend, but ran out of light for the trouble shooting part:
everything seems to be installed correctly but i get no spark. the directions state that for applications where there is no balast resistor or resisitance wire the coil should have at least 1 ohm resistance. mine reads 0 (zero) on the multimeter.
this is for a '52 3/4 ton, running 12v and the original 216 and it's ignition.
thanks
-b
