The 55-59 maintenance manual says free play adjustment= 1". The 63 Chevy Truck manual says 3/4"-1". The 80-87 Chevy truck manual says 1 3/8"-1 5/8". In your case you need to try something to see if you can affect the engagement. Something is way off. The "no movement "indicates too small of a free play. The "not shifting" into some gears indicates too much free play. You may have two problems at the same time. Clutch and internal tranny. I assume you tested tranny before install to see that it shifted. BTW what tranny is it?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn |
