| | | Forums66 Topics128,179 Posts1,057,068 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | first id see if my distributor turns when you rev it. your vacuum advance on the distributor should make it turn a lil bit when you rev. if your vac advance isnt working the car will not run right when revved.
then determin if its a fuel,electric of vac leak problem.
put a visible filter between the pump and carb, that way you know that fuel getting to the carb,
pull off your carb, fill the bowl, and see if your carb is squirting when you work the throttle body/
check the float and needle, make sure it drop freely and not hanging up, preventing gas from flowing into the carb.
if carb seems fine and squirts when worked. investigate your points,timing, and check for vac leaks
