1 members (LAROKE),
63
3
Mod | | | Forums66 Topics128,194 Posts1,057,263 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | you can't make frankenstein carbs and expect them to work. This is probably why you are getting no responses, it is somewhat inconceivable to me why you would try and mix up pieces. What exactly do you have that vacuum advance hooked up to anyway. Disconnect that and plug the "tube" that you have it hooked to. I have forgotten to re-connect the advance for quite some time (several months? before I noticed) and noticed no difference in the way it ran. You would probably do well to get the right carburetor, they aren't horribly expensive. I don't believe you will ever get that conglomeration to run.
Entire Thread
235, idle takes off, runs way to fast? :(
| drew_vigil | 03/02/2013 6:49 PM |
Re: 235, idle takes off, runs way to fast? :(
| brokenhead | 03/03/2013 6:03 AM |
| DADS50 | 03/03/2013 7:12 AM |
| MtneerMike | 03/03/2013 8:02 AM |
| drew_vigil | 03/03/2013 9:31 PM |
| Pre '68 Dave | 03/03/2013 11:26 PM |
| drew_vigil | 03/04/2013 8:36 AM |
| b10 | 03/04/2013 3:33 PM | |
