0 members (),
123
8
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | You're kind of out of luck in that department. There's been a few of us here that are working on a disc brake upgrade. There is also a guy in California I believe that has come up with a kit, by machining a later model hub and installing a bearing spacer. I'm not really fond of his kit, because of the bearing spacer and it moves everything outboard of the spindle, affecting your scrub of the tire. Here's a couple pics of what I'm working on. I'm using components from a 2007 GM van. The 13" rotor is the way I'm going to go. The caliper on the 12.8" was just too large to come up with a good bracket to mount it. BTW 3/4 ton, 1 ton, and some 1.5 ton trucks used the same bearing and hub assembly from 53-59. http://s1074.beta.photobucket.com/u...amp;_suid=136225217756608223982073469883http://s1074.beta.photobucket.com/u...mp;_suid=1362252233910018386534533993337
