3 members (1955 1 Series, KEVINSKI, Charles in CA), 92 guests, and 4 robots.
Topics128,185
Posts1,057,207
Members48,465
Moderated
Moderated
I own a 1955 2nd series 1 ton and I'm having it restored. I want to update to disc brakes. All the searching I've all I can find is 6 bolt stud pattern, my truck is 8. Any one on this forum have experience with this? I'd appreciate any iin put offered.
You're kind of out of luck in that department. There's been a few of us here that are working on a disc brake upgrade. There is also a guy in California I believe that has come up with a kit, by machining a later model hub and installing a bearing spacer. I'm not really fond of his kit, because of the bearing spacer and it moves everything outboard of the spindle, affecting your scrub of the tire.
Here's a couple pics of what I'm working on. I'm using components from a 2007 GM van. The 13" rotor is the way I'm going to go. The caliper on the 12.8" was just too large to come up with a good bracket to mount it. BTW 3/4 ton, 1 ton, and some 1.5 ton trucks used the same bearing and hub assembly from 53-59.
http://s1074.beta.photobucket.com/u...amp;_suid=136225217756608223982073469883
http://s1074.beta.photobucket.com/u...mp;_suid=1362252233910018386534533993337
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
