0 members (),
37
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#92217 06/24/2005 6:24 PM | Joined: Jan 2003 Posts: 24 Junior Member | | Junior Member Joined: Jan 2003 Posts: 24 | I have a '51 AD 3/4 ton with a new generator, new voltage regulator and a new battery (all 6 volt).
The problem is that the ammeter showed a good charge (about half way between 0 and full charge) up until a few days ago. For a while the ammeter showed that the system was discharging, but now the needle sits almost exactly at 0, showing a little bit of charging at higher RPMs and a little bit of discharging at idle. Turning on the headlights moves the needle to the discharge side.
What should the readings be? What might have happened? What can I do to get the system functioning properly?
Thanks in advance.
Rob | | |
