The 1951 door has unique characteristics. It has the later vent window and the earlier turn-down handle. You will not be easily able to get it to match either the earlier door or the later door. However, you can get it to work on any A-D cab, but using the 1951 and earlier door latch/striker(catch) parts.
I think this is what you ended-up with in your post.
