When my valve body had a sticking problem, i was not even able to manually shift through the gears. Is it possible that 1st is just really short and soft? I have a 4.11 rear end and my TH350 generally shifts from first to second around 10mph and from second to third around 20mph. His RPMs seem about spot on for the speeds and setup that he is running.
