Thanks for the input guys. I filed points in regulator and adjusted to shop manual spec. but could not get more then 2.8 volts after first ajustment. I thought I might have damaged generator??? I followed Randy's "Tech Tips" and grounded F terminal to engine block and ammeter showed good charging rate.
To make a long story short, I bought new 6 volt regulator from NAPA ($73.00) ouch!!! and it is starting great and charging at 7.8 volts.
I think my old reg. might still be good if I could get it dialed in right. So it's on the shelf for now.
And on to my next project. New clutch/plate/T-bearing, and I might as well take care of that leaking rear main while I'm down there.
I've been reading old forum messages to see what I'm in for. Lot of good stuff in there!
Thanks, Jim
---------------------------------- 54 Chevy 3100 deluxe 54 Chevy 4400 flatbed/dump 72 Chevy C/40 flatbed/dump 292" 1954 44001954 3800Jim D. '41 Chevy 1-Ton Pickup/dump...292" 4-speed w/Ranger OD ... Newest Truck '54 Chevy 3800 Dump........New Truck! '54 Chevy 4400 flatbed/dump, Gone to my brother-in-law '13 GMC 1500 daily driver ... 5.3 6-speed auto just turned 13k miles '01 Chevy 2500hd, might be my new daily driver ... 6.0 / 4L80-E
