The 292 is the only stovebolt 6 I'm aware of with offset motor mounts. It should also have a bellhousing bolt pattern the same as a smallblock V-8. The harmonic balancer will be heavier than the other 6-cylinders of similar vintage, plus it's a little longer. Good engine, and the price was right, too!
