Hydra-Matic from the 1954 Chevrolet Truck Shop Manual
Driving Instructions
The Hydra-Matic has a neutral safety switch in engine compartment on the steering column... There are two purple wires that go to it...
The Hydra-Matic holds about 8 1/2 quarts of fluid... It has been recommended by Gene at Restoration Hydramatics to use Vavoline Detx/Merc ... Under the floor mat, if there one left, is a round plate towards the center of the floorboard, remove the plate and there is the dip stick... To check the fluid level the engine and transmission has to be at running temperature... I usually drive it to get the fluid circulating...
Looks like its in good condition from your pics... The 3100 emblem looks like the 54 style ... Check your Vin # at the VIN Buster to be sure of the manufacturing year...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
