| | | Forums66 Topics128,032 Posts1,055,519 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | First measure the diameter of the rod to make sure it is a 1/4". Next go buy a brand new die that matches your Heim end threads and run it down the rod. The Heim now fits. A very sharp die is necessary so it can cut across existing threads every several rounds without getting diverted. Another approach is to use a thread gauge to find out what threads are on the rod and get a tap from a machine tool supply and run it in the Heim end. This leaves an invisible fix but a special order tap can be pricey.
Evan
