5 members (Bill Hanlon, 68ironhead, 48jim1ton, Hotrod Lincoln, Otto Skorzeny), 121 guests, and 2 robots.
Topics128,032
Posts1,055,517
Members48,425
#907128 12/29/2012 5:02 PM
I installed an Edelbrook carb. the stock linkage will work perfect,I just can't find a heim joint or fitting that matches threads on the stock rod. Not sure what the threads are. They are finer than 1/4-28. Any help would be great.
Thanks Brett
First measure the diameter of the rod to make sure it is a 1/4". Next go buy a brand new die that matches your Heim end threads and run it down the rod. The Heim now fits. A very sharp die is necessary so it can cut across existing threads every several rounds without getting diverted. Another approach is to use a thread gauge to find out what threads are on the rod and get a tap from a machine tool supply and run it in the Heim end. This leaves an invisible fix but a special order tap can be pricey.
Evan
Another approach would be to take the rod to your local hardware store and find the what size it is. I know that ACE has cards with both SAE and metric thread sizes on them.
Larry
I don't own a vehicle that isn't old enough to drink.
