Zenith makes an excellent carb; however one was never original on your truck. To determine if the carb is applicable for the 235, we would need to know the number on the Zenith tag.
As a general rule, too small a carb will run too rich up to a point, where it just won't run; too large a carb will run lean (need to add choke).
Jon.
The Carburetor Shop
