"1960-62 engines will not have the front side mounting provisions"
..that is correct. I had forgotten about the engine mount change. I was only thinking about the AT fitting it. However the front mount can be installed on a 60 engine so it can still be used w/o major difficulty.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
