12 members (HandyAndy, 3B, Oswald, Gdads51, 1955 1 Series, Jon G, Southerntruck, Otto Skorzeny, Gray_Ghost, Peggy M, 2 invisible),
155
2
Mod | | | Forums66 Topics128,103 Posts1,056,183 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#90162 03/15/2002 9:10 PM | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | Oldblue , some of the new horn replacements are ment to work in the jap cars or german car whict are not wired the same as the older american (they use two wires) cars. The wire you took off your old horn put on one terminal (does not matter which) then make up a short wire to go from the other terminal to a good steel (not plastic) ground. | | | |
Entire Thread
Horn Replacement, 1 wire to 2 wire
| oldblue | 03/12/2002 12:32 AM |
Re: Horn Replacement, 1 wire to 2 wire
| acme | 03/12/2002 4:16 PM |
| oldbluetruck | 03/12/2002 6:21 PM |
| Curly | 03/13/2002 6:43 AM |
| oldblue | 03/14/2002 12:52 AM |
| squeeze | 03/14/2002 4:51 AM |
| oldblue | 03/14/2002 7:42 PM |
| 49 geezer | 03/14/2002 9:50 PM |
| oldblue | 03/15/2002 12:50 AM |
| ALBERT | 03/15/2002 9:10 PM |
| C1534 | 03/16/2002 3:56 AM |
| 49 geezer | 03/17/2002 12:59 AM |
| C1534 | 03/19/2002 12:55 AM | |
