1 members (mick53),
92
Mod | | | Forums66 Topics128,290 Posts1,058,557 Members48,491 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Like Leon said, make sure the alignment rings went in straight. If you can not push the manifold up tight to the head with out the help of the bolts STOP. A lot of the time the exhaust manifold warps up at the ends. If this happens the alignment studs on each end keep the manifold out of position for the intake rings to line up. A lot of the times I have to leave out the end alignment studs.
See the USA in your vintage Chevrolet! My Blog | | |
