| | | Forums66 Topics128,089 Posts1,056,418 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | The steering shaft with worm gear you need fits ALL Commercial and Utility Trucks from 1934 thru 1936. It should be stamped "No. 89" and is 45-3/32" long. The Pitman Arm Shaft (Sector and Shaft) you need fits 1936 1/2 and 1-1/2 ton trucks only and is part number 262946. Hope this helps, Mike B  | | |
