5 members (Nick in Manitou, 1955 1 Series, FishinToms53, Otto Skorzeny, Hotrod Lincoln), 88 guests, and 3 robots.
Topics128,089
Posts1,056,437
Members48,443
#897533 11/18/2012 10:19 AM
Are you familiar with the old Saginaw worm and sector in the '36 chevy?
Mine is so worn I cannot adjust it. I need a new worm gear and I have never
seen one on Ebay-only for '37's and newer. Do you know if a '37 worm would work
in a '36 gear box? Help I am out of ideas. I have this beautiful '36 ton & half in my barn
that I have worked on for 7 years and cain't drive it. Thanks in Texas.
The steering shaft with worm gear you need fits ALL Commercial and Utility Trucks from 1934 thru 1936. It should be stamped "No. 89" and is 45-3/32" long.
The Pitman Arm Shaft (Sector and Shaft) you need fits 1936 1/2 and 1-1/2 ton trucks only and is part number 262946.
Hope this helps,
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
