| | | Forums66 Topics128,069 Posts1,055,890 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 401 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 401 | OK, so I have all the lines replaced and hooked up to my hydrovac. I am now looking at the vacuum and fresh air lines that come from the HV and go to the Intake Manifold (vacuum) and the fresh air line that coneects to the air cleaner. Being that I have a different motor and air cleaner that is more modern, do I just drill a hole in the base of the air cleaner and connect a fitting for the air line to connect to? Or has anyone else done something different? | | |
