I have a 48 cab with 48 doors (original)
Plan to use 52 door handles on it because I like them, need to weld in the proper reinforcing plate from the 52 and change a few holes in the door skin. Also using aftermarket latches in the swap. Not sure if later model latches fit the older doors (with exception of outside handles) I'd guess they do?
Grigg
