You should have a switch at the lower end of the steering column just on the topside.With the key in the on position(Wheels blocked of course) check the terminals while someone moves the shifter from park to reverse,neutral and back again.I do not remember which terminal it is as I wired in spot-lights through their own switch.I mounted the lights under the rear bumper.Just do not leave the lights on when there is a police vehicle folowing you eek grin
There is enough good in the worst of us and enough bad in the best of us that it does not behoove any of us to criticize the rest of us.
Be yourself. If you are ever lost, It will be much easier to find yourself if you know who you are!
