3 members (gswbbc, Millenimech, jmoore), 90 guests, and 2 robots.
Topics128,031
Posts1,055,434
Members48,422
#88928 10/18/2002 1:33 AM
I have a '70 C10 and I need to know how to wire the reverse lights. They were disconnected by the p.o. and I don't know where the wires from the lights connect to. All help appreciated.
Ralph Davis
1970 Chevy C10 Webshots
My Stovebolt Gallery page
Old trucks never die, they just find a new home.
You should have a switch at the lower end of the steering column just on the topside.With the key in the on position(Wheels blocked of course) check the terminals while someone moves the shifter from park to reverse,neutral and back again.I do not remember which terminal it is as I wired in spot-lights through their own switch.I mounted the lights under the rear bumper.Just do not leave the lights on when there is a police vehicle folowing you eek grin
Mechainiac, does this mean you had yours on with a bubble machine following you?
Thanks luke, I will check it out this weekend.
Ralph Davis
