msteuer - factory turn sigs were an xtra cost option in the task force. the wiring diagram came with the unit. pretty straight forward. the large plastic wiring connector for it should be under the dash by the steering column, and the unit just slides on the column under the wheel with the wiring going down the column w/ the horn wire.
I could send ya some pics if ya want. could probably send ya a whole unit, but Joy might get excited!
