I assume you are using a jump joint to go from the 3600's drive shaft to the firebird's axle? Thats a huge difference and you will want to align these closely.. sure you want that car axle in a 3/4 ton?
With the box not being on the truck you will want to make sure you have the axle closely centered from side to side.. else you get a tire rub on floor supports
good luck
1950 Chevy 3600
Instagram/Olbluechevytruck
on Classic trucks:
http://rides.classictrucks.com/ride/1085750/olblue/1950/chevrolet/c20/
