| | | Forums66 Topics128,050 Posts1,055,675 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the late 50's/60's car shroud is slightly wider than the truck rad and the hole spacing down each side is slightly different, probably that's what you have - if it looks like this .... it works with a bit of fudging, but on a 57 you could move the rad back like the factory did and fab the sheet metal top and bottom Bill | | |
