4 members (k2handyman, moparguy, dt235sd, Hotrod Lincoln), 71 guests, and 1 robot.
Topics128,049
Posts1,055,678
#884470 09/24/2012 6:03 PM
I recently came across a fan shroud I believe is from a late 50's early 60's Chevy. I cannot find any markings on it. Does anyone know how far about the bolts holes should be for these years? I measured my '57 V8 truck and find 25 1/4 from center to center on the radiator bolt holes. This one is 27 1/4 center to center. Thanks in advance
57cameoguy #884484 09/24/2012 7:28 PM
the late 50's/60's car shroud is slightly wider than the truck rad and the hole spacing down each side is slightly different, probably that's what you have - if it looks like this .... it works with a bit of fudging, but on a 57 you could move the rad back like the factory did and fab the sheet metal top and bottom
Flxible #884485 09/24/2012 7:35 PM
Thanks Bill, The first picture looks like the fan shroud I have.
57cameoguy #884489 09/24/2012 7:56 PM
that one came from a 62-64 sedan, the circular part is identical to what the 58/9 truck used
