| | | Forums66 Topics128,087 Posts1,055,982 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You can use most bell houseings for 55-72 v-8 & 63-72 six cyl. The exceptions are the 68 up 4 speeds & some 3 speeds had a larger center hole. I have a '63-'66 inline 292 ( block code 3851659 ) in my garage. So can I use both the bell housing and flywheel off that engine for my 283? Yes. The early 292 had the same size flywheel mounting holes as the v-8 but the later ones had 1/2 in holes. Make sure the flywheel has the correct bolt size. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
