Hi Bill
A lock wedge??? I've taken out the nut and bolt that appear to hold the pin in by sitting in a groove in the pin. Is that what you're referring to? I'm curious, because it didn't mention a wedge of any sort in the manual.
Getting a punch on the inside must have been kind of tricky too with the space being pretty tight. I noticed that on the inside it appears that the pin sticks thru the part of the chassis that holds the spring on, right?
Thanks for the help!
Chris
Chris
"I'm sure those leftover parts aren't needed"
55 Chevy Series 2 pickup, "Buddy"
