| | | Forums66 Topics128,035 Posts1,055,447 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Starters will also interchange as long as we are talking 6 volt to 6 volt or 12 volt to 12 volt. The 228 flywheel will have a 6 volt ring gear. The 235 could have the 168 tooth 12 volt ring gear.
The 6 volt and 12 volt starters will bolt up to the bellhousing without issue. Just have to make sure you have the correct flywheel ring gear. A 6 volt starter will run fine on 12 volts, but a 12 volt starter will not run on 6 volts. | | |
