| | | Forums66 Topics128,071 Posts1,055,901 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 283 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 283 | Those of us trying to keep em' running in the 70's saw a bunch of this "sometimes pluggage" on the vahicles of the late 60's-early 70's---mostly GM. Many times the vehicle would run normally for days and then shutdown on the road only to restart after a short rest. Sometimes you could make it repeat by making a high speed or load effort like open throttle uphill. I never found out what had changed in the way the vehicle was made from earlier or later but the plastic gauze type filter on the pickup was at fault and sometimes left a imprint where it was sucked up against the pickup tube.After the suction was interrupted it backed off and buisness as usual. Sometimes mechanics would blow back with air to clear the situation but the real cure was replacement of the pickup assembly or rip off the filter and install a good inline.
Bob Taylor
