7 members (1955 1 Series, Bill Hanlon, Otto Skorzeny, rfs56trk, DHedrick, Robert Crandall, klhansen),
123
3
Mod | | | Forums66 Topics128,087 Posts1,056,399 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87819 05/21/2004 1:42 AM | Joined: Mar 2000 Posts: 1,182 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,182 | I'm not real familiar with the wiring for your truck, but it sounds like the wire that feeds voltage to your gas gauge is in the same circuit as the wire that feeds your coil, and something came loose when you hit the bump. I'd check for loose connections or a pinched wire somewhere under the hood. Trace the hot wire back from the coil and see what it leads to. | | |
