| | | Forums66 Topics128,088 Posts1,056,414 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87818 05/20/2004 10:02 PM | Joined: May 2004 Posts: 36 Apprentice | | Apprentice Joined: May 2004 Posts: 36 | Hello,
My 1940 1/2 ton with 216, went over a few bumps. The gas gauge went dead then she stalled. I lifted the hood, pushed in the coil and plug wires and she started right up. The gas gauge then read normal.
What happened, I would like to fix so it doesn't happen again.
Thank you.
Mark | | |
#87819 05/21/2004 1:42 AM | Joined: Mar 2000 Posts: 1,182 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,182 | I'm not real familiar with the wiring for your truck, but it sounds like the wire that feeds voltage to your gas gauge is in the same circuit as the wire that feeds your coil, and something came loose when you hit the bump. I'd check for loose connections or a pinched wire somewhere under the hood. Trace the hot wire back from the coil and see what it leads to. | | |
