I just tested the spark at the coil wire. Following advice on some earlier threads, I pulled the dist cap off, pulled the wire off the center terminal of the cap, set it close to a ground, and then separated the points with a wooden stick. There is only an intermittent spark when I do this and the spark looks to me to be very very weak.
