1 members (Gdads51),
84
3
Mod | | | Forums66 Topics128,139 Posts1,056,447 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Your disc is stuck to the flywheel. You can get underneath & remove the lower cover. Prop the clutch pedal down & use something thin to pry the disc from the flywheel. Or you can prop the clutch pedal down, put the trans. in high gear & rock the truck back & forth. You will feel it when it comes loose but dont have it where it can roll away. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
