| | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | It seems like it was the perfect storm. After sitting for 2 years it appears I had several problems all at once. Took the carb apart and found the needle value was stuck, rebuilt it and ran much better - for a about 20 minutes. Replaced the plugs and cap and rotor and noticed a big difference in performance - until I hit 30 minutes. Replaced the coil and ta-da! Thanks for all your suggestions. You all were right!! | | |
