1 members (Hotrod Lincoln),
79
0
Mod | | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | I had the same problem and replaced the cable but that wasn't the problem. Check out this diagram: http://chevy.oldcarmanualproject.com/1929_54chevyparts/04/316.HTM. It turned out that the slot on my 5.150 (extension) was too deep so lever 5.149 would not move it when the brake was applied. I took the extension to a shop and they welded some metal into the slot to make the slot shallower so when the lever was moved (forward) the extension moved the front shoe onto the drum. I hope this makes sense.
It's a small world, but I wouldn't want to paint it.
