| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | An OD transmission swap is another way to crack the 45 mph barrier. You will likely also have to swap a full pressure 235 for your tired 216 to get the benefit of OD.
The 1 ton may have 5.13 gears, so switching to the higher 4.56 3/4 ton gears may give you some improvement. Double check the actual ratio, and play with the online gear calculators to see what rpm your truck is spinning at current speeds. | | |
