0 members (),
125
2
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87327 07/06/2002 2:10 AM | Joined: Jul 2002 Posts: 1 Junior Member | | Junior Member Joined: Jul 2002 Posts: 1 | hello, im rewiring my 38 chevy 1/2 ton. The truck had no harness so there's nothing to go off of. the new one is the stock style. I wanted to convert to 12 volts and did that on a 54 truck so i understand that. Does the 38 truck have a voltage regulator? if not when converting to 12 volt should i use one. i do have one to use. so if I should what do I do? In the wiring diagram sent there is no voltage regulator. Similiar to the 39 truck wiring diagram on this sight. In the manual there is one(6 volt)But there are four posts coming off of it. 12 volt regulator dont have the ignition post. please help there more info the better. Do I take wire off the ameter(fuse style)and change to regulator? thanks | | |
