So I assume there is no special connection or way to position the fuel pump. Right? Originally, i assumed that if I bolted it onto the block correctly, then it should contact the cam and work.
This evening I'll pull it off the block and use a mirror to look inside to see if that cam looks rounded off. I kinda doubt that is the case since the engine only has 88k miles. I'll post an update.
Thanks
