Depending on where you are going to put the door I would make a template to take with you so you can get as close of a match to the contour as possiable. This saves on the body work down the line. 60-66 Fleetside Chevys a Mitiubtchi PU. door works very well.
I might not of spelled it right for sure but hope you can decifer the Japanese name.
62Blue
Don
