| | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 71 | Hello everyone,
I've finished the initial cam break in on my 235, and now I need to tune it. It is a 56 block, with a carter YF carb. After the cam break in, I tried to lover the idle to 425, but it started to sound pretty rough about 800 rpms. I never heard a good running 235 at idle, is it supposed to sound kinda like a diesel?
Second, do you set the idle, timing, or adjust the carb first? I was planning on adjusting the carb with a vacuum gauge, and the timing with a light. I assume all changes should be done on a warm engine, correct?
Thanks for the help,
Vince
Entire Thread
235 time, tune, idle questions
| Coachie | 07/10/2012 12:14 AM |
Re: 235 time, tune, idle questions
| tclederman | 07/10/2012 10:12 AM |
| Coachie | 07/10/2012 7:23 PM |
| tclederman | 07/10/2012 7:30 PM |
| Kurt_51carryall | 07/10/2012 7:32 PM |
| Coachie | 07/10/2012 7:51 PM |
| Coachie | 07/10/2012 10:12 PM |
| tclederman | 07/10/2012 10:17 PM |
| Coachie | 07/10/2012 10:35 PM |
| Coachie | 07/11/2012 12:09 AM |
| CASO | 07/11/2012 12:57 AM |
| tclederman | 07/11/2012 9:21 AM |
| Coachie | 07/18/2012 9:23 PM | |
