| | | Forums66 Topics128,154 Posts1,057,014 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | The frame on a 1/2-ton (GMC unique 100 model/long-frame, see picture of one I parted) This truck is simply an extended 1/2-ton truck with 1/2-ton suspension pieces. http://good-times.webshots.com/photo/2967102110102454676BWyNDCThis frame is going to be 46-1/32" wide at the rear. a 1949 3/4-ton frame at the same location is 36" big difference. It is in the rear where the major differences occur due to the heavier rear differential and spring set-up. | | |
