Originally Posted by red58
so either your new sender is defective [most likely], the gauge is actually bad, or the wire to it has a short when you hook it up
Thanks for all the replies so far
Well then it's between the sender or the gauge, because the wirings all new and I checked that as well.
Just bought a new sender, i'll be throwing that in tonight or tomorrow. I'll post what happens then.
