| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Don't whack 'em- - - - -use a long piece of pipe just big enough to fit over the stud, (probably 1/2") and gently pry the stud whatever direction it needs to go. You'll have better control over the movement than you will if you hammer on the stud. Jerry
