Thanks for your reply and the link, Tim.
I would like to use the foot pedal actuated parking brake, and I believe I'm going to have to, as there is no hand lever assembly on my transmission.
I believe I can use the '51 cab's transmission cover since it wasn't too banged up in the accident.
My area of concern is with installing the foot pedal system. This was a point of impact and the components took a beating.
It also seems that the '53 cab isn't set up to recieve a foot pedal sysytem. For example, there isn't a hole for (what I believe is called) the anchoring rod. Edit: Actually, it's called a "lock bar".
Any information and/or guidence is appreciated.
Dave
The Blue Funk: a '51 3100 4 OTF with a '57 235
More pix on Photobucket
