| | | Forums66 Topics128,082 Posts1,055,961 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | By 'meter' Red59 means ampmeter. If a meter is not available I like to use a test lamp (looks like an icepick with a lamp or bulb in the handle and a wire pigtail hanging out). A couple of bucks at your FLAPS. I prefer to pull the neg. battery cable off (either side will work). Clip the pigtail wire to the cable and icepick point to battery post. With everything electrical off on the truck, the lamp should not 'burn'. If it glows, do as Red58 suggest, start pulling fuses.
