ya lucked out! cool the electric wipers were optional in the task force trucks, w/ the vacuum unit being the most common by far - should be able to bench test it easy, and the only problem I've ever found is w/ the switch and the cable-knob mechanism - watch for bad connections and blown fuse . . .
